onehundred80
Update March 19th 2015
The 20028 has been fitted and programed by the Chrysler dealer only and found to work fine, the 20066 model has not yet been tried and proven. Make sure you get the correct part, 20028 or 20066 as either are possible.
A-Programming Tool Required B-Magnet Required to Activate Sensor C-20018 and 20008 are interchangeable.
Click here to download the Schrader AirAware TPMS manual
Original post
Schrader lists the following parts for the Crossfire (Coupe, Limited and SRT6);
Schrader #20028 for '04, '06,'07, and '08 for $49.99 plus service kit #20003 for $2.99
This replaces OEM part #5096808AA
Schrader #20028 (see above) or #20066 for '05 (Limited and SRT6) for $65.99 plus service kit #20013 for $5.24
These replace OEM parts #5096808AA or #5142340AA respectively.
The '05s and '05 SRT6 could have either sensor in them so check carefully.
The OEM numbers listed above are for the sensors only, there are other OEM numbers out there and I think those are for the complete sensor assembly consisting of the sensor, the nut and the cap.
The service kit has the rubber seal for the rim, valve, nut and cap.
DO NOT BUY THEM FROM A STEALERSHIP
These part numbers are to be used carefully, different sites have shown various numbers but the ones above seem to be consistent. In other words buyer beware. Check exactly what you are replacing, if the dealer gives you the wrong part it is his fault, you buy the wrong part and you may end up eating the cost.
Universal sensors are replacing the multitude of sensors on the market, the sensor available now only replaces one of the two types used on the Crossfire. This would be some of the 05's and some of the SRT's.
The following sensors (EZ Sensor) have NOT been proven to work, stay with the AirAware sensors, 20028 does work, 20066 is not proven yet from info gleaned on this forum.
Schrader EZ-sensor #33000 EZ-sensor - Quick Start Guide
This sensor comes with two options, snap in or clamp in stems. Crossfires use the clamp in stem which is the metal. stem. The stem is screwed to the sensor and is replaceable.
The 33000 only replaces one of the two sensors used on the Crossfire, the 5142340AA (20066). This is the sensor used on some 05's and some SRT6's.
We have a report in the crossfire Facebook group that this cloneable type sensor works on the crossfire...
"Richard Jones
Here's the item and product number - ITM UNI-SENSOR 433MHZ, product # 08003HP"
