Old Sep 8, 2016 | 09:22 AM
onehundred80
Default Re: 178mm AMG StgII Crank Pulley....
Originally Posted by No2fast
I am pretty sure it is a custom pulley. it was build from a stock crankshaft pulley. a stock pulley (same part no.) looks like this: http://bilder3.eazyauction.de/YourCa...lder/47495.jpg
you can see the difference in height from the pic if you compare yours.
AFAIK ASP takes a new stock pulley to build a 178 pulley.
Damned I missed the auction !
Steven
Berlin Germany
I agree as on the back side you can see the two set screws that are meant to stop the slipping of the new outer grooved ring that has been pressed onto the stock pulley which has had the original grooves machined off.
