Old Sep 9, 2016 | 06:46 PM
EbonyXF's Avatar
EbonyXF
Default Re: Multifunction switch part numbers
The part number is on the switch, if you still have the old one it would be easy to see.
Describe your problem, maybe it is not the switch.
If the switch is on the left hand side of the steering wheel I would say it is the same part.
You have an extra digit in the first numbers of the part number it should say 170 I think.
I've not taken it out yet so cant see any numbers on it.
The problem is the turn signals stop working. I can turn on the headlights, pass to flash function, wipers all work off the stalk and the four way flashers also still work so I know it's not bulbs. On previous occasions I have messed with the fuses behind the headlight module/switch and then they worked again, (not sure this is just coincidence) But the last time they were off for a whole day.
When they start working again they will work for about a week then they will stop again!
I have already had the stalk replaced with one from a breaker and had no trouble for 2 months but then it's started again. I wasn't sure if it was something to do with the headlight switch module or the stalk again?
