Old Sep 9, 2016 | 07:47 PM
onehundred80
Default Re: Multifunction switch part numbers
Originally Posted by EbonyXF
I've not taken it out yet so cant see any numbers on it.
The problem is the turn signals stop working. I can turn on the headlights, pass to flash function, wipers all work off the stalk and the four way flashers also still work so I know it's not bulbs. On previous occasions I have messed with the fuses behind the headlight module/switch and then they worked again, (not sure this is just coincidence) But the last time they were off for a whole day.
When they start working again they will work for about a week then they will stop again!
I have already had the stalk replaced with one from a breaker and had no trouble for 2 months but then it's started again. I wasn't sure if it was something to do with the headlight switch module or the stalk again?
What do you mean by messing with fuses?
Fuse 4 is for the turn signal bulbs and the back up lights, do your back up lights work?
Maybe the fuse is faulty. I assume you have the same fuse positions as us over the pond. Check the chart on the switch fuse panel.
