Old Sep 19, 2016 | 01:01 PM
onehundred80
Default Re: My P0410 secondary air code fix
Originally Posted by ChrisA
Will a RCM from a 320 SLK work in a Srt6 Also do you need to disconnect the battery when switching them out?
Yes it will work. It should have the correct number (Part # A 170 545 03 05) but I would check maybe someone made a mistake in the first place so you should try and make sure it is what it is supposed to be.
Actually some other RCM work as well and they have different part numbers.
I would disconnect the battery, maybe not required but better be safe than sorry.
