While your under there looking around, check for any damage done BEFORE you stored it. It might not have been noticeable before you stored it and now that you took her out it got noticed. Suggest you put it on a set of stands with the fuel pump/filter cover removed, you might see where it leaks. Better yet, you really don't have to 'start the motor, just have someone 'cycle' the iggy to on (not to start). That will kick in the fuel pump. If it is opened up (the cover) and your help turns on the key to 'ON', look for any leakage. Just a suggestion! Be careful while under there (which is why it is better on stands, right? Good luck!
