Re: 20 psi need help
No2Fast
- Popular pump and seems slightly more efficient than the Walbro - ie: pulls similar amps but produces more flow (at nominal volts of 12V). This is sometimes an indication of better engineering.
However - the extra flow is not needed here unless someone is thinking of more psi.....;>)
I've added data to pump chart in previous post.
Note: There are 2 versions of this - a high perf. and the std. one which I've quoted.
