Re: 20 psi need help
The AFR's much better....
You dont mention what your pulley setup is.
How are you getting 20psi if you arent already stacked?
A 65mm will only give you 17.5 and a 62mm maybe 18+ a nudge.
Also the Nm seem way too high.
Stock they do 450Nm at the crank let alone at the "Torque Rear" which I presume means the rear wheels.
I'm guessing by the mBars this is at Sea Level.
