Old Oct 3, 2016 | 09:50 AM
Mackel's Avatar
Mackel
Default Re: What Happened? Need Diagnostic Help
Plus 1 on what ala_xfire suggests. Check for loose grounds/cables OR is it possible a rodent got in and is devouring insulation? Slight vibrations could explain some if a rodent has been active. Good luck!
Thanks, Graphite. I have no traces of rodents residing in the garage. No droppings or sightings. Wife would let me know in very short order if she sees one. I'm going to try ala_xfire's battery suggestion. I'll keep your rodent alert in mind in case I still have electrical weirdness after replacing the battery and checking the ground cable.
