Old Oct 3, 2016 | 04:54 PM
onehundred80
Default Re: What Happened? Need Diagnostic Help
Originally Posted by ring175
Hi Guy's.....
Beeing the Newbie on the site......Could some one explain the SKREEM fix, I have done the batt off, key to on, 15 minutes, key off and Batt on bas erp light now appears, but starts no problem.
The diagnostices show no error codes as everything goes back to normal....I thought error codes were held.....nothing showing....It seems to go back to normal................still not sure about driving it.
Help Please... Ring 175
I see no foul here Mackel all threads are open for discussion and additional inquiries. This person used the possible cure for the SKREEM problems in his post that has been the subject of some debate and which I added in the thread about Crossfire Problems and Repairs. In your case I would try the reset that he did, you never know and it costs nothing. Remove your RCM from the car, open it up and plug it back into the car and see if the relays are working properly.
After that I would try another RCM, the problem may lay in it.
Ring175, welcome to the forum, I see you are from France.
Presumably this resets everything back to zero in the cars memory, like rebooting your computer after a glitch has occurred.
What were your symptoms before the reset?
I am glad the reset worked.
