Old Oct 7, 2016 | 06:11 PM
Ard227's Avatar
Ard227
Default Convertible top alarm
With top down all works fine.
With top in up/closed position, alarm sounds off. After aprox 1/4 mile it stops until I go slower than 7 mph then it sounds off slow beep and stops again when I go past 7 mph.
After a little while alarm will sound off again until I push convertible top button and it will stop again.
Also while top is in open position I can raise or lower trunk wing manually.
While top is up I can not operate wing manually but it does work when I go past 65 mph and lowers automatically also.
My reservoir is at the min level ? Does this have a sensor that will make it sound off ? If so what fluid is used?
Is there a hidden sensor or switch? I checked all I can find including one in upper windshield header and above passenger head.
Can anyone help me ? !!
