Old Oct 11, 2016 | 07:13 AM
maxcichon's Avatar
maxcichon
Default Re: 245/35R19 Front tires - damage from upper ball joint? Need opinions...
Originally Posted by ShawnQ
I think I am going to go with a 235/35R19. I need new front tires regardless. I may also try to go from my 12mm to a 15mm spacer.
Looking at the damage on the tire, it's hard to tell if it is contacting the bolt, the nut, or both. I'd rather not file them if I can prevent it. I also hate to put a brand new tire on it just to 'test' it...
I figure the damage is caused only when the tire was under lateral stress-being pushed inward at the top under cornering. There is a little movement/flex in all things.
