Old Oct 12, 2016 | 08:12 PM
ShawnQ's Avatar
ShawnQ
Default Re: 245/35R19 Front tires - damage from upper ball joint? Need opinions...
I run 235/35/19's on the front, 8 1/2 with a 15 mm spacer.
Mine is close, but it doesn't touch. The narrower tire should fix that.
Do you think a 12m spacer would work for yours? I have 12s. Debating on whether I need to order a set of 15mm spacers or not....
