Old Oct 14, 2016 | 02:36 PM
ala_xfire
Default Re: Wet Passenger Side Floor
Get that water out of the lower compartment of that passenger side! I say this because if the carpet is wet, then there probably is a puddle below the carpet. You do not want all that wiring/stuff there to sit in it (may be too late already).
If you don't have the amp/related wet there, it will be good for you. Check that area!
The TCM is also there snuggled up next to the amp on automatics.
