Old Oct 25, 2016 | 04:15 PM
GraphiteGhost
Default Re: A lot of issues after taking apart the interior
One thing that JUMPS right out at me, previous post alluded to it. Could you have PINCHED a cable or harness while reassembling? If you 'ground' or 'short' things in a pinched area, it could play he!! with figuring it out. So, take out the things with cables/harnesses and reconfigure/check the routing when reinstalling. IF there is a pinched wire/cable, you have to check it is a reliable connection where it is supposed to go (not cross connected, if wires are broken into). Good luck!
