Re: air intake swap, now cel on
well put in new gas peddle and did reset but didn't fix it . removed cover on throttle body and cleaned . then did 5 min battery disconnect and then another peddle recalibration . so start it up, no p0123 code . drive it and now it runs like a na car . supercharger wont kick in but it doesn't go into limp mode anymore . you can throttle all the way and it just runs like a car without a super charger . but when you get to the stop sign and then accelerate again the throttle works fine , so the problem where the throttle would go unresponsive is gone .
torque pro shows the throttle % only going to about 50% so i'm guessing throttle body is bad ? ordered used throttle body to swap out , so we'll see .
on the way home cel came on checked it again , no p0123 code but lots of others . now i'm really confused .
