Old Oct 27, 2016 | 05:38 PM
GraphiteGhost
Default Re: Any tips for winter storage?
Unhooking the battery should not cause problems UNLESS you unhook the POSITIVE terminal first (alarm goes nuts). Long term, if you disconnect it, just make sure the battery top does not have any dirt/scum on it. This dirt/scum has enough 'continuity' to drain the battery some over time. Once a month hook up a trickle charger.
Last edited by GraphiteGhost; Jan 1, 2018 at 04:59 PM. Reason: Correction found by 180 Thanks Dave!
