Old Oct 30, 2016 | 01:41 PM
GraphiteGhost
Default Re: battery indicator light
Yup, my Graphite was the same way. I used the cable I showed you, attached the smaller wire to the stud in your picture and ran the heavy one to the block - the way we did it for HOW many YEARS?
GG, I prefer my way, as the stamped terminal/cable connection is more resistant to corrosion than a lug under the ground bolt at the chassis.
Yeah PG, six of one, half a dozen of the other (some will recognize that comment), whenever I use a terminal lug in a vehicle, I solder after crimping to prevent water absorption. After that I seal with a very good grade of electrical tape. Know all too well corrosion finds its way into crimp only connections. Just as good your way of course!
