Old Nov 2, 2016 | 03:45 PM
ala_xfire
Default Re: rodent chewed tube
That tube has nothing to do with starting, I suspect your pets did not stop there.
This is a vacuum tube that runs from the rear of the manifold through the firewall under the battery tray and does the air flow actuation for the AC/heat.
If it's not too bad, it can be repaired with some slightly larger rubber vacuum tubing from an auto parts store.
