Old Nov 6, 2016 | 07:30 AM
oledoc2u
Default Re: Technical Expert
If you look thru some of the sticky's on here for fixes, you will find one about the pump failing that supplies cooling for the supercharger. If it is failing, it will tell the supercharger to quit working until the temps go back down. So the 'air intake sensor' could be bad or the coolant pump could be bad. The pumps fail if original. Easy fix. Less than a 100 bucks. Rarely is it the sensor, but I did have one fail on the roadster. I would replace the coolant pump first. I buy my parts from Needswings.com. If you are near Chuk, he will have no problem fixing your car. Less than a half hour.
