Re: SRT6 Reliablity With High Mileage
Usually, yes.
Cold air has a higher density than hot air, thus more air in each intake stroke, more power.
Admittedly not a whole lot, but every bit helps.
The OEM intake on the SRT6 and NA models has two tubes that run to the front and pull air from in front of the radiator.
The NeedsWings single and dual CAI's do the same, the difference is better flow characteristics.
You do understand that the SRT6, although old by modern day standards is still a high performance platform capable of beating 90% of the new Camero's and Mustangs right ?
It is not to be trifled with, at age 18 you should take caution, it is a very good handling car with excellent brakes, but that doesn't prevent stupid drivers from pulling out in front of you !!
It is also NOT a good snow car, best leave it at home.
