Old Nov 10, 2016 | 02:03 AM
oledoc2u
Default Re: Leaking Intercooler
check hoses, if you still have the belly pan on, you will see fluid build up under there. If not, then Billy22Bob suggestions would be next to look at. Good luck. But the intakes are too clean, as no build up of sludge from leaks. Doesn't mean it just didn't started though. May have not had time to show the build up. Good luck with your search.
