Old Nov 11, 2016 | 09:52 AM
onehundred80
Default Re: Shifter Sticks And Is Hard To Get In Gear
Originally Posted by Padgett
Clutch mot releasing properly is more likely a leaking master or slave cyl piston seal.
If you have a leaky slave cylinder then when it is pushed to the floor and you leave it there in gear, would you not find the car starts to inch forward as the cylinder leaks and let's the clutch plate move into contact with the flywheel more?
Surely the master cylinder does not enter into the equation as only the reservoir is used for the oil supply.
Maybe some springs on the clutch have broken, that has happened before here.
