Re: What did you do to your Crossfire today?
Replaced the fuel relay control module and crankshaft position sensor. (Lesson learned: I should have changed both out at once).
In the summer, my SRT-6 threw a code on the road. Drove to the nearest Autozone. The salesman said I should change the fuel relay control module.
About a month ago, I started stalling. (I had just bought new front tires the day before). I sent my fuel relay module to Tighed for the fix, and put it back in
The second time I started it up after replacing the module, my problems re-occurred. Tried to drive it to my local Autozone but it stalled near home. Left it there overnight, limped it back home.
Bought an OBD code reader from Sears, bought a new module off eBay, put some RCR fuel cleaner in the tank and put the module in. More trouble. 10 codes at least, my Sears scanner said.
Drove to my local Autozone and made it all the way there. They only got three codes but one of them was P0335 (which the Sears scanner did not pick up). Bought a sensor from them on the spot, got home and put it in.
Started it back up. Still running rough. While my Sears reader gave me 12 codes, Autozone only spotted four: P0306, P0206, P0412 and P0135. Salesman wanted to sell me an injector on the spot. I think I will check my coil pack and wiring in the area of cylinder 6 first.
