Old Nov 13, 2016 | 08:41 PM
onehundred80
Default Re: What's this part?
Originally Posted by curtisr
This is a smog pump aka secondary air injection pump. The part number is 05098830AA.
Here's what the MB folks say about it:
An air pump is used on the vehicle to lower tail pipe emissions on start-up. The Powertrain Control Module (PCM) grounds the Air pump relay control circuit which energizes the Air pump. The PCM also grounds the Air combination valve vacuum control solenoid circuit, which energizes the Air vacuum control solenoid. Vacuum is then applied to both Air combination valve diaphragms which opens the shut off valves. The PCM enables both circuits simultaneously when Air system operations id desired. When the AIR system is active, then Air pump forces fresh air into the exhaust stream in order to accelerate catalyst operation. The AIR combination valves replace the conventional check valves. When the AIR system is inactive the shut off valves prevent air flow in either direction.
If you're seeing a Check Engine light or are experiencing hesitation at take off they recommend replacing it.
If you have the CEL then there are much cheaper options available than replacing it. The problem is most likely a bad ground, or a bad relay. The cost of these is zero or $6, if you want to replace the pump you are talking hundreds of dollars. Take your pick.
The fault does not affect performance at all, you just will not pass any required pollution tests.
