Old Nov 15, 2016 | 10:40 AM
onehundred80
Default Re: intermittent very hard start.
Originally Posted by ZERACER
After that I found that the car was better but suddenly it started having a very hard starting issue.. intermittently. at this point the check engine light came back on and I swapped out the cam shaft sensor as well.
So what you are saying is that the original sensor had failed exactly the same way as its replacement? This would appear to be true as there were identical symptoms present.
Something does not sound right here. Although the symptoms are that of a Cam Shaft Position sensor.
Reverse signal? What is that?
A weak signal or no signal is what normally happens when they fail.
Last edited by onehundred80; Nov 15, 2016 at 05:19 PM. Reason: Quote was from wrong person
