Old Nov 22, 2016 | 06:37 PM
ala_xfire
Default Re: Need source for Auto Shutdown relay
One very important thing you should check in to is the "sticky key fix"
It may have already been done, if it has then the person 'should' have left a note to that effect inside the driver side fuse panel door.
( also, the RCM re-solder is well worthwhile, as well as a CPS replacement with a Bosch CPS )
