Thread: High Idle
Old Nov 25, 2016 | 08:33 PM
onehundred80
Default Re: High Idle
Originally Posted by RKC00
RE: 2005 Limited, Manual, 51k Miles
I recently purchased this as my long time retirement toy. Completed the 74mm Throttle Body Upgrade. Completed memory reset. Idles as it should until it reaches normal operating temp. Then the idle bounces between 1200-1800rpm for about a minute then it settles down to around 750rpm. Does this every time I come to a stop. Suggestions to remedy? My previous toys were 350z's. I appreciate your knowledge and guidance.
Did you install a new seal in the throttle body when you installed it?
If you installed the MAF as well did you install the old MAF sensor from the old MAF unit? You must do this.
Have you pushed the engine cover firmly in place?
Did you reinstall the vacuum lines properly to the throttle body?
Some hints here. CLICK
