Old Nov 26, 2016 | 06:21 PM
onehundred80
Default Re: Only third brake light working
Originally Posted by cartoonguy2002
I'm having this issue, center brake light is working, other 2 brake lights are not working. I just changed the bulbs and I'm still having the same issue. I had O'Reillys order the "brake switch" (on the pedal arm) it was inexpensive and then I can cross it off the list.
My top is not going down, windows go down then I get the slow beep.
Electric seat adjusts are not working.
Driver's side heated seat is not working. (never worked) bought the car used.
Have you tried the speed control?
If it does not work as well it's the fuse.
Check the fuse anyway, it's quicker.
