Old Dec 9, 2016 | 03:30 PM
ala_xfire
Default Re: brake vacuum booster
Have you removed each caliper and looked inside around the cup seal ?
That's the most likely place for a leak.
I suppose the master cylinder could be leaking past the piston seal back to the booster, drop the master off the booster and look inside.
Also check the 4 flexible hoses to the calipers.
