SRT 6 Engine parts, most all, used
Dec 13, 2016 | 01:14 PM
permalink
UrbanE
Dec 2014
1,255
301
CA
Re: SRT 6 Engine parts, Great quality, used
I'm posting this updated list of Parts onbehalf of JimmieC. Please contact Jimmie for details.
I have recently purchased the Timing cover, EGR valves and Crankshaft. All are in 100% perfect condition.
Regards,
UrbanE
Chrysler SRT-6, Mercedes SLK 32 AMG 3.2 Parts
Good Quality Used 40K or less
Packed and stored in humidity controlled/climate controlledwarehouse since March 1, 2014
6 coil packs w/12 plug wires $480.00
Injection Nozzles (all 6) $350.00
Intake manifold Plenums, Pair $450.00
Exhaust Manifolds, pair $175.00
Cylinder Heads (3.2SRT,AMG pair) $1,418.00
Camshafts, (SRT, AMG 2 each for boosted engine) $1,080.00
Camshaft gears, (SRT, AMG 2 each) $ 50.00
Rocker arm assemblies Complete (AMG Pair) $450.00
Valve/Cam cover assemblies (3.2SRT-6, pair) $176.00
Enginemounts (oil Filled Pair) $ 75.00
CamShaft Position Sensor $ 45.00
CrankShaft Position Sensor $ 30.00
62mmPulley for Supercharger (new) $450.00
72mmPulley (Stock) for Supercharger $200.00
Duct,Air Inlet to throttle body with boots and clamps $ 75.00
Ypipe 1.6 AMG supercharger Intercooler Discharge to intake plenums $200.00
FuelRail, AMG/SRT6 $ 75.00
OilCooler SRT/AMG with S Shaped hose to water for cooling $214.00
StarterRing Gear for 3.2 with Automatic Transmission $ 30.00
Balanceshaft with spur gear for oil pump chain w/bearing and weight $105.00
Timingand oil pump drive chains, 2 with guide tensioners $ 50.00
Upperoil Pan 3.2 Mercedes SRT6 $145.00
Loweroil pan 3.2 Mercedes SRT6 $ 50.00
OilLevel Sensor with internal upper pan wiring (3.2Mercedes, SRT6) $100.00
Chain,oil pump $ 12.00
Chain, timing $ 70.00
ChainTensioner $ 48.00
Chainguide , right and left $ 24.00
Chainguide, upper $ 12.00
Aluminumtubing and rubber hose plumbing, air pump to ERG valves $100.00
Pulley,crankshaft, seven groove SRT6, 3.2 AMG, stock 155mm $134.00
UrbanE
View Public Profile
Send a private message to UrbanE
Find all posts by UrbanE
