Old Dec 14, 2016 | 07:34 AM
zip439's Avatar
zip439
Default Re: What's this hose and help with a leak
Originally Posted by Swampotter
I hate reading about problems that never seem to have a conclusion but if someone reads this months or years down the road, yes my transmission was leaking at the electrical adapter plug and was wicking up the wires. It's all changed out now so hopefully it's all fixed. Thanks for all the help.
If that area near the amplifiers damp as you stated in your first post, It often happens that the drain in the cowl is clogged with leaves/trash. When the drain is plugged water finds its way into the car. You should remove the cowl (between the hood and the windshield) from the outside and be certain the drains on both the driver and passenger side are clear. You will need a pulley puller to remove the wiper blades from their shafts to get the black plastic cowl removed. It is a common and recurring item that should be addressed at regular intervals particularly if you park near trees.
