Re: Headlight bulbs
OK...installed new bulbs both sides...low and high beams work, but need major alignment upwards (is this normal?), and now the passing high beam toggling is not working. The forward toggle on the stalk to high beams works, showing the high beam indicator in the instrument cluster, but nothing happens when I pull back on the turn indicator stalk, either high beam or high beam light indicator.
Any thoughts out there?
Thanks
Thomas
