Old Dec 16, 2016 | 10:28 AM
onehundred80
Default Re: SRT6 supercharger question
[QUOTE=meh03;877130]Is it normal for the front of the supercharger that spins to have a little play? See the pic. When I grab this and turn it by hand I can hear and feel a little play. Probably about a 1/16" turn play. I don't remember it being that way back when I changed the pulley about 15k miles ago.
I also noticed I'm pretty sure my 65mm eurocharged pulley is the aluminum one?
It looks to me that you are holding the electro magnet in which case the answer is there should be very limited play in it, so little as to be unnoticeable. This runs on the SC gearbox shaft bearings and not on the SC pulley bearing.
If you mean the clutch plate moves slightly in relation to the pulley, then I would say the rivets may be loose.
