Old Dec 19, 2016 | 03:51 PM
GraphiteGhost
Default Re: Broken engine wire
Originally Posted by kamilspider
Hah, yes, for sure is ground wire but for what?
I would think if the wire itself isn't broken, then it is fine for electrical continuity. If your concerned about any exposed bare wire through the insulation, wrap it in a good rubber electrical wrap (like electrical tape but heavier, made to 'blend' into itself like a rubber coating). Unless it has 'chaffed' into other signal/voltage carrying wires, your quite OK to just wrap it. I would think taking it all apart (the harness) to replace it, would be extremely hard. It also would probably not look like it does now, seeing as it (the entire harness) has aged in its position. Like when you unpack a box with a lot of parts, then try to put it all back in the box the way it came, never goes right.
Rereading your post, are you trying to get rid of it? It is there for a reason, I would leave it alone.
