Old Dec 20, 2016 | 01:03 PM
GraphiteGhost
Default Re: Broken engine wire
Originally Posted by kamilspider
This wire is truncate. It's only 10cm. I can not find second part this wire.
Anybody can check in your car where go this wire?
I want fix it, not leave it
Fix what? It doesn't look broken in the picture you posted. Is it cut, is it 'open'? Is it just insulation off the wire? Fix it is fine, this involves covering it if insulation is missing, splice if broken OR a complete opening of the harness and pulling it out to its other end. How deep do you want to delve into it is entirely up to you. Good luck with whatever is wrong with it. So far, I am not sure exactly what is wrong with that ground since the picture isn't clear enough and so far your explanation is vague.
