Old Dec 20, 2016 | 08:24 PM
onehundred80
Default Re: Climate control blows warm air, A/C is fine
Originally Posted by Swampotter
Sorry all, it's a new car and I finally have some time off, if you can tell. Here's the latest thing on my list to fix. Here it goes.
The climate control constantly blows 95 degree air at its coldest setting. It blows 140 at its hottest setting and with the A/C on it gets down to 55. Its 70 outside so the question is, why is it always blowing at 95 on the lowest dial settings? I'd figure that it should be close to outside temps.
Both drivers and passengers temps are the same. My guess is the duovalve is slightly stuck open but before I tear into it I wanted to get some feedback from the members. Thanks.
The valves under the hood are not working, does it blow the same on both passenger and driver sides of the car. The valves should shut down when the temperature is dialed down with the AC on.
These valves.
