Speedy4x4
AGM is the preferred battery for upscale motorcycles. Being sealed, AGM reduces acid spilling in an accident, lowers the weight for the same performance and allows installation at odd angles.
Ty, dedward
That site says sealed also.
Motorcycles are not 4 wheeled crossfires! AGM batteries in a car/truck is a personal preference. AGM batteries in vehicles that tend to lean/flip/roll/climb, or any other geometry are preferred since wet cells can and do leak when other than level by a few degrees. So, if you plan on parking on or continually climbing and decending steep hills (or sideways on hills), buy an AGM battery. IF the wet cell is filled properly, and your charging system is not defective or damaged, you should not have a problem with post corrosion. For the batteries that leak around the posts and cause corrosion, regular maintenance for that battery (cleaned and kept clean) is fine. This discussion is starting to look like the 'oil' preferences (and the like) posts!
