Re: Electric radiator fan stays on
Hi
It sounds like you've done something while installing the radio. Did you remove the climate control unit when fitting it? My suggestion would be to check the plug on the back of your climate contol unit. If it's not plugged in properly the fan will run and the AC won't work.
