Old Dec 30, 2016 | 05:51 PM
ala_xfire
Default Re: Buzzing noise after shut off!
Originally Posted by freestyle45
So, I have this problem and removing the fuse has stopped the noise. Thank you very much!
What does removing the fuse do other than magically stopping the noise, how do I do a proper fix etc.?
Cheers again
This most likely means that the contacts on the aux air pump relay in the RCM are fused together in the closed position. Remove the RCM and contact tighed1 at tighed1@hotmail.com for instructions on where to send it.
EDIT : I see you are over the pond, might be easiest to find a replacement RCM at a breakers .
( If you won't ever need to pass emissions inspections, just leave the 40 amp fuse out )
