Old Jan 1, 2017 | 04:14 PM
onehundred80
Default Re: Base M112 E32 Engine (Turbo Project Early stages)
Originally Posted by XFireFreedom
I have a 2005 Crossfire 6speed complete stock. Srt6 and Base have the same M112 engine. I always thought that since it was the same engine then if I were to do custom turbo build then the engine could handle the boost. After research, the C32 AMG M112 has a lower compression ratio of 9:1 while my base M112 E32 has 10:1 CR. I want at least 12-14psi. Could I boost with the high compression? Yes, but that requires a dang good tune and still little margin for error, and I'm already using 93 gas and you're going to need more octane if you boost anything higher than 10:1 for the boost I want (from what I understand). PS This will be my first turbo build.
My questions:
1. How can I lower the compression ratio to at least 9.5:1 or lower, the easiest way. I would prefer not to have to change out the piston connecting rod or get a domed piston head (thats a lot of work to take the engine out and I am not that skilled of a mechanic, besides, and the piston rods in the srt6 are $200 a piece, and the base m112 comes with forged pistons which can withstand the boost I want anyways). Could i increase the combustion chamber by swapping/modifying the heads? what other easier ways can I lower the compression ratio in this engine.
2. Has anyone ever freaking done a turbo build for the BASE model crossfire that wants to give me some helpful tips or need-to-knows.
Miscellaneous:
ECU ideas? (should I just go piggyback?)
Will the stock injectors be fine at 14psi boost?
I will be have a shop do a complete custom exhaust from manifold. (has anyone found a turbo header manifold online?).
I'm here for advice. If I am wrong on anything I have stated above as far as facts, point it out if you need to.
Try putting 'turbo' in search.
You'll get something like this CLICK and much more.
It'll take at least two weeks to read it all.
