Old Jan 9, 2017 | 02:28 AM
onehundred80
Default Re: Climate control blows warm air, A/C is fine
Originally Posted by Swampotter
I'm back. I did the Heater/AC Fan Speed Control fix. I've given it a week and although it worked a little better the situation never fully resolved itself. The next step was to check the blend door. I removed the plastic cowl below the windshield and noticed the door was in the closed position. I gave it a little push and it opened. I then turned the car on and started the climate fan. I next hit the Rest button and watched the door close. I then turned off the Rest button however the door stayed closed. I'm assuming it should have opened up to allow fresh air in. Any suggestions?
Look at the vacuum line underneath the battery, it is damaged by battery acid.
The flap actuator is behind the glove box I think, that has caused problems as well.
