Old Jan 11, 2017 | 05:08 PM
ala_xfire
Default Re: Cranks and no start
The filter does indeed have a check valve that should maintain pressure for quite some time after the engine is shut off.
To see if this is the problem, just turn the key on for about 5 seconds before trying to start, that should build up pressure.
Another possibility is an injector allowing the fuel to pass without being triggered.
Does it smoke a bunch when first started ?
Does the oil look diluted with gasoline ?
Here is a diagram of the fuel system :
