Old Jan 12, 2017 | 06:36 AM
Oconnom's Avatar
Oconnom
Default Re: Weak air flow from heater vents
Hi,
Stil have ongoing issue with low airflow from heater vents. Latest check was to insert a camera upstream of the fan to check for blockages on the heater core, none found. My next thought was a faulty fan motor i.e. a fan that spins slower than norma,l even when supplied with full voltage. Wehn set to fastest speed I measure 12v across the motor and 15 amps flowing tjrough the motor via fuse 36.
Can someone measure their current through fuse 36 with engine running and fan set to fastest speed so I can compare ?
Thanks in advance
Mick
'06 Aeroblue Coupe
