Old Jan 13, 2017 | 03:47 PM
onehundred80
Default Re: OEM Windshield Wipers with Deflectors
SWF is a European maker of windshield wipers and they fall under the Valeo owned company's. CLICK
Look down the page and you'll find ours are the Windspoiler design, I have OEM wipers arms for both sides and only the driver side is the Windspoiler design.
My OEM drivers side is 20" long wiper and the passenger side is 22" long. When I picked up the car I found the 22" blade on the driver side, the 20" blade was on the passenger side. I cannot remember any problem with that set up but I switched them back to the correct side.
You can find 22" SWF Windspoiler blades on eBay CLICK.
I wonder if you could run 22" blades on bother sides, or use the 21" SWF Windspoiler from eBay CLICK on the drivers side, with the 22" on the passenger side.
The description of these blades says they are for use on the left hand - drivers side only.
Worth a try I'd say. but the force that keeps them against the windshield will get reversed as they go past 90°.
