Old Jan 14, 2017 | 07:45 AM
waldig's Avatar
waldig
Talking Re: Which Battery Tender to Use
I added the two prong connector and a FUSE IN LINE to the battery. The cord comes out the hood on passenger side near wiper and if I gets stupid the thing will disconnect when I back up first. I can hook and unhook the cord with the hood closed and the fuse allows safety from shorts or pinched wires on hood hinge. Safety is easier before you need it. I use the wall mart charger tenders and always test the voltage with a meter before leaving it on the battery. Now and then a tender will go high and cause a problem as noted above. Float should be in the 13 volt range, not 14s or higher , for a FLOAT charger. Enjoy, Woody
