Old Jan 15, 2017 | 11:23 AM
onehundred80
Default Re: Transmission pan gasket leaking
Originally Posted by Pierantonio
Had gasket replaced by a local shop 3 times. It is still leaking. Is there a trick to this or could it be some other problem? The last time it was there they replaced it with a gasket from Mercedes.
Are you sure it is not the transmission connector socket that is leaking? This is a common problem and costs very little to fix, the O-rings in it fail and leak oil. It is a round yellow object, just above the pan, with wires coming out of it. It is on the passenger side.
Failing that get another shop to look at it.
