Old Jan 16, 2017 | 03:29 PM
Whipy's Avatar
Whipy
Default Re: Should I buy a Crank Position Sensor
Originally Posted by Indelibility
Yes! Order a Bosh sensor and keep it, and the tools to swap it in your glove compartment. It's a 5 minute roadside fix and you'll thank yourself later.
5-minute roadside fix ?
I have so far spent several hours trying to remove the bolt that holds it in on my SRT without success. Do you have any special trick you use? Getting hands in there is almost impossible. getting enough leverage on the E8 Torx bolt to loosen it IS impossible, at least that is my experience. All the time I'm trying to loosen this bolt I am terrified that I might succeed because of how tough it will be to put it back ...
Why the heck did they put this bolt UNDER the CPS so you cannot see it or access it ??
Any help you can offer will be appreciated.
