Old Jan 20, 2017 | 11:27 AM
onehundred80
Default Re: Weak air flow from heater vents
I am not too sure how this problem was found after two plus years, two wires from the resistor what could be messed up. I cannot get my head around it, did you have it all apart?
Originally Posted by Oconnom
The good news I've sorted my weak airflow from the heater blower ! It was a simple fix suggested by a mechanic friend and was, wait for it ! The plug on the motor was inserted the wrong way around, so the motor was blowing in the oppsite direction. Although the speed controller module has different sized terminals to prevent incorrect connection, the 2 pin plug on the motor can be inserted either way !!!!!! It was either like that from the factory or a previous owner inadvertantly plugged it in the wrong way. Initially I thought a blower motor going backwards would suck air, but no, it simply blows very inefficiently due to the design of the fan blades.
Mick
