Re: What did you do to your Crossfire today?
I replaced the cigarette lighter housing, part # 05102786AA. I removed the plastic vent cover on the passenger side (plastic fastener, 1/4 turn). Then the screw behind the cover. Remove the plastic cover to center console. Reach in and push the lighter out. I needed to pry slightly on the outlet from front. Disconnect wiring. Connect wiring and the lighter will heat (be careful), it will then pop out. Remove the lighter element. Place the housing in hole. When the plastic is flush, use the handle of a screw driver and push the metal part until it clips.
